Div. Teile für High Performance Mustangs von John Ruth/USA
Im Auftrag
Beitrag von Im Auftrag »
Mustang Road race parts
Shelby R Model / Early Trans Am fibreglass race bucket seat has tube frame around back for added strength $250
1 set of 289 HD main bearing caps – for fitting to 289 block to make to HiPo spec $200
1 original 65/66 Mustang door drivers side , very good condition - $400
1 original 65/66 Mustang front fender drivers side , very good condition - $300
Each Detroit Locker Diff Asm is 28 spline and ready to bolt in ( $750 each firm )
3.70 ratio – NOS factory iron housing, Detroit Locker differential, factory pinion support, small cap bearings
4.11 ratio – factory housing, original rebuilt Detroit Locker differential, Factory pinion support, small bearing , small cap bearings
4.30 ratio – factory N case housing, Detroit Locker differential, FORD Daytona pinion support, large cap bearings
1 pc FORD 9”Daytona pinion support and pinion flange $200
1 pc FORD Std 9” pinion support and pinion flange $125
1 set of Shelby R Model / early Trans Am rocker covers $200
1 pc Aviad R Model style oil pan and pick-up $350
1 pc Shelby lettered alloy hi-riser intake manifold $400
Demon 750 Double Pumper race carb / mech secondaries with throttle linkage $450
2 pc new narrow 1 3/4" 155lb Trans Am spec leafs springs with new shackles ready to install $450
2 pc new 580 lb coil springs - use with above to have a balanced car $165
* Package price for above = $500, ready to install with hardware
1 set of FORD factory strut rods with mods to adjust very cool and correct and ready to install $200
1 set of front Cobra Automotive 11.9” rotors with gusseted billet steel caliper brackets and cooling duct brackets
1 set of billet steel heavy duty hubs with bearings and spacers / extremely durable comes ready to install
* Package price for above 2 items = $1,800
1 set of rear 10”x 2 ½ “ drums $175
1 pc of original Kelsey Hayes 10 x 2 1/2" drum backing plate / the same as Shelby used $180
1 set of original Shelby Belanger drag race headers $150
1 set of FORD Motorsport / Roller Rocker set, ratio = 1.60 $120
The below spindles are recommended, as they are stronger and allow for larger wheel bearings + a larger tie rod stud
1 set of FORD heavy duty big bearing spindles with upper ball joint installed $250
1 set of FORD heavy duty big bearing spindles $235
Shipping is at buyers expense and in addition to above prices. Parts are located in Michigan
John Ruth
Info/Kontakt über T5owner
