Ford 302 351 390 Kupplung komplett neu OVP McLoad Street Pro
Verfasst: Do 28. Dez 2023, 20:09
				Kupplung noch originalverpackt, nie geöffnet. Ich habe das Kit für meinen 1969 Mustang Boss 302 gekauft, aber nicht gebraucht.
Neupreis bei Summit, CJ Pony Parts oder direkt bei McLoad liegt bei $355 plus internationaler Versand.
Genaue Bezeichnung - Street Pro Kit 75112: 1962-83 Ford 11“ x 1-1/16“ x 10: Diaphragm
Für Ford 302, 351, 390ci, Spline 1-1/16“ x 10, Disc Dia 11“, Type Diaphragm
Preis liegt bei 355 Euro
Information von Summit Racing:
• Alignment Tool Included Yes
• Clutch Disc Quantity Single
• Clutch Usage Performance
• Counterweight Assist No
• Disc Diameter (in) 11.000 in.
• Disc Diameter (mm) 279mm
• Disc Material Organic
• Disc Style Full face
• Flywheel Included No
• Hub Style Sprung
• Input Shaft Diameter 1.063 in.
• Input Spline Quantity 10
• Mounting Hardware Included No
• Pilot Bushing Included Yes
• Pressure Plate Style Diaphragm
• Quantity Sold as a kit.
• Throwout Bearing Included Yes
Information von Jegs:
Ford
• 1969-1974 351ci Opt D P/P
• 1968-1974 302ci Opt D P/P
• 1970-1973 351ci Opt D P/P
• 1963-1970 390ci Opt D P/P
• Street Pro: Kit:1962-83 Ford 11" x 1-1/16x10: Diaphragm
The Street Pro is the perfect choice for an entry level performance clutch for the street. We recommend it for cars up to 400hp (depending on part number) with mild engine mods and street tires. Included is a high clamp load pressure plate, an organic disc for smooth and even engagement with increased holding power over stock. Our kits are complete with Pressure Plate, Disc, throw out bearing (where applicable) pilot bushing (where applicable) and alignment tool. If you are looking for a clutch that's a great step up from your stock set up, the McLeod Street Pro is the clutch for you.
Specifications:
Part Type
Clutch Kit
Product Line
McLeod Street Pro Clutch Kits
Yes
Clutch Usage
Street
No
Disc Diameter
11 in (279.4 mm)
Disc Diameter (mm)
279
Disc Material
Organic
Disc Style
Sprung Hub
Flywheel Included
No
Hardware Included
No
Horsepower Rating
400
1.063 in (27 mm)
10 in (254 mm)
No
Number of Discs
Single
Package Depth
3.20
Package Height
14.60
Package Width
14.00
Part Fitment
Direct Fit
No
Diaphragm
Quantity
Sold as a kit
Shipping Weight
25.30
Spline
1 1/16" x 10
Yes
Throwout Bearing Style
Standard
Vendor Part Number
75112
• Hub Style Sprung
Ford
Specifications:
Part Type
Clutch Kit
Product Line
Yes
Clutch Usage
Street
No
Disc Diameter
11 in (279.4 mm)
Disc Diameter (mm)
279
Disc Material
Organic
Disc Style
Sprung Hub
Flywheel Included
No
Hardware Included
No
Horsepower Rating
400
1.063 in (27 mm)
10 in (254 mm)
No
Number of Discs
Single
Package Depth
3.20
Package Height
14.60
Package Width
14.00
Part Fitment
Direct Fit
No
Diaphragm
Quantity
Sold as a kit
Shipping Weight
25.30
Spline
1 1/16" x 10
Yes
Standard
Vendor Part Number
75112
